EBC, Fitness Sugnature and Progression Chart don't match
Today I had a breakthrough according to The Activities Section (18/8/2024) of the home page. My fitness signature says TP = 249 but doesn’t indicate break throuigh from 224 TP to 249-250. Nor does the Progression chart. I shows only my old TP = 224. and no Break Through medal. EBC shows TP = 249 and a Break Through medal.
What’s going on? Why the difference in power TP readings?
Data calculations on the mobile apps are trimmed down versions of the deeper dive analysis performed on XO.
Sharp power spikes, for example, are stripped out on XO.
This means a BT can be triggered on the mobile app that doesn’t past muster when the sec by sec analysis is performed on the server.
How sharp is sharp? I mean if I get a BT notification for how much longer after it should I keep pushing to make it to get past XO filtering? 3 sec? 10 sec? longer?
Thank you!
In general any effort that exceeds MPA over 5 secs will be sufficient to trigger a BT adjustment.
Here’s the various ways that can happen (pull, push, multiple, near) –
