Do Garmin Connect IQ fields work on an Explore 2?
I’m trying to install some Xert Garmin Connect IQ fields on an Edge Explore 2. Unfortunately the Explore 2 is not listed as a supported device. Is that accurate? I do have an old Edge 530, which is listed as supported. If I download the Edge 530 version from Connect IQ would that work on the Explore 2?
Thank you!
Currently only XSS Buckets lists Explore 2 as a compatible device.
I imagine that device will likely be added when the other Connect IQ fields are updated for use on the 1050.
Buckets may eventually end up providing most Xert data fields in one app. :slight_smile:
Garmin Connect IQ apps are compiled to each Garmin product. Garmin Explore 2 is a separate target, so unfortunately it will not work. But I assume it should not be that much work for Xert to add support.
Hadn’t looked at XSS Buckets. Looks like that already provides what I was interested in.
Thanks!
