Delete zero speed from tcx file
Hello,
I import tcx file from polar flow, but the zero speed values are imported in xert from the tcx file. Do you know if it is possible to delete the zero speed value from the tcx file before import in Xert?
Thanks for your response.
Not really - you would need to manually edit it, with a plain text editor and delete the zero speed (time elapsed) section(s). But the the total will be off, unless you adjust that in the first section of the file.
There are (online) TCX editors, but they will probably disregard the power when you save the file.
Other than that, Xert uses your zero speed section(s) to calculate various things and those are considered rest, i.e. recovery.
