Combining Cycling, Zwift and running profile with Stryd
Hello! I am new to Xert, watched all the videos and have played around with the features. I have 2 questions regarding the running profile as I run on top of my cycling training.
1. On top of my cycling I run with a Stryd pod (mostly outdoors but sometimes on a treadmill connectedt to Zwift). I created a second profile for my running activities. Apart from changing the freshness slider on my cycling profile there is no other “smarter” way to account for the running activities done on top of my cycling?
2. I need my run activities to be synced via garmin directly because if they are synced via Strava, if I do a virtual run (Stryd+Zwift → Strava → xert) the power readings are not displayed since Zwift does not measure running power. Whereas they are synced if I sync Garmin → Xert. The problem is that for my cycling activities I need to sync Strava → Xert because all the data (power etc.) is there and the name of the activity is unchanged and there is the little Zwift map etc. Is there no way to differentiate syncing “rules” between the 2 profiles? I.E. Run = sync from Garmin only, Cycling = sync from Strava only.
Final, unrelated question, if I want to use the Android EBC app (magic buckets, SMART workouts etc.) with my DiretoXR in Zwift, I understand I need to get a ANT dongle so my DiretoXR is connected to one bluetooth device (the android app). Are these ANT dongles compatible with AppleTV? (So AppleTV –> ANT –> DiretoXR but not controlled, and Android –> Bluetooth –> DiretoXR controlled).
Thank you in advance!
