Bc the small dots that open the menu for configuration doesn`t open in Garmin Express?
The latest Garmin Express update appears to have some issues. Could you kindly approach Garmin support on this issue? We’ll apply some influence on our end too. In the meantime, you may want to configure the apps using the Garmin Connect mobile app. First you’ll need to pair your Garmin unit with the phone using Bluetooth. You should see the installed apps and have the ability to configure them this way.
Yeah - definitely a better experience using the Garmin Connect mobile app.
Apparently, if you right click the app in GE, you’ll be able to configure the settings.
