Hi All,
I’m experiencing intermittent signal drops for HR and cadence. How can I fix this?
Couple basic troubleshooting tips that you may want to try… turn resetting bluetooth (off & back on) under your iOS settings. You can also try restarting the phone if you haven’t done that recently.
Hi Scott,
I did what you suggested and it partially worked for cadence
However, now I have a bigger problem: The app doesn’t connect the HR strap anymore. I changed the battery in the strap, it connects to the iphone and works fine on my garmin computer.
Kindly help!.
It appears to be working again with a reinstall of the app….
Ok. I have the problem again…Do I have to reinstall the app before every time I use it??..that seems crazy. Please help
@havella Did you ever find a solution to this? I’m having the same issue.
Solution was to leave Xert
2.4 wifi networks and micro ovens can create this problem.
