I’ve seen this a few times now, on my garmin I can get the 3s average power way above the current MPA, say 600W vs 400W, and the garmin will flag a breakthrough (i highlighted a large gap as a small gap 600W vs 580W I could see being suspect due to timing and averaging issues), I usually have a few more attempts after that point maybe 30-60s later, and I’ll again go past the MPA. However the breakthrough is then indicated on the second/third attempt and not the one that the garmin flagged.
In the example below the garmin tripped on the 2nd/3rd peak, which here shows as not being near to being a breakthrough. My first thought is that the MPA is updated retrospectively for this ride, which physiologically makes sense, but if I had not done the 4th effort would there have been a breakthrough, or if the increase from the 4th effort was not applied would there have been a smaller increase from the 3rd effort that would be a breakthough? The gap looks to be about 90W, the increase was 21W, so I’d still be 69W short?
As you suspected it always shows the new signature. There is a button on breakthrough activities to show the previous signature at the bottom. Then you see which parts of your activity were above your old signature.
Brilliant, thanks, I’d played with the other buttons before but they seemed to continually update some values everytime I pressed them, so I left them alone.
@Idexfix is spot on! Since it’s not possible - by definition - to be above your MPA, the system needs to determine the new signature such that your power can meet/touch MPA, but not exceed it.
Using the ‘Previous’ button should display what you saw in real-time in EBC or Garmin MPA data fields.
