Hi, I had a breakthrough… but Xert didn’t know what to do with it… so didn’t change anything. Can you do some additional analysis?
As background: asthma and lung function has been my limiter. After a lot of breath work I was able to access a new level. So it is a legit recalibration of ability.
Short high-power efforts don’t always register as a BT.
That final blip with immediate stop was likely interpreted as a power spike when analyzed on XO.
You can send a request to support@xertonline.com and ask for assistance with a manual adjustment.
Or do this yourself by viewing the activity chart on XO, raise TP a bit at the bottom, hit Extract, and continue tweaking until MPA no long flatlines and just touches the tip of the highest spike.
If you agree with the change, select Save to use the adjusted signature moving forward.
Super helpful. Thank you for the response.
Was super easy and I didn’t realize the profile numbers at the bottom were editable. Again, thank you for the guidance.
