Any advice on best athlete type for Dirty Kanza 200? Just got in and have sufficient time between now and May 30 for a full Xert program. Its 200 miles of rolling hills and wind with a few famously stiff climbs, all day and into the night. I’m thinking GC - or would it be better to opt for an even longer focus in light of the sheer distance (century maybe)? Appreciate any thoughts.
I’m doing a 300km/180mile ride in June, so quite similar.
The advice given to me yesterday seems relevant:
Thanks very much Daren. GC and pushing the TL makes lots of sense.
Keeping your Athlete Type at a very long focus duration is really going to do is going to give you almost 100% low strain, so you’d likely never really be recommended any workouts with lots of intensity (which makes sense for that athlete type), but it really is good to have some variety in your training. Moving yourself up the PD curve is going to give you a wider range of workouts for XATA to choose from, and as I elaborated above the Athlete type is about the intensity of the race/event that you’re training for, not the duration. Think of all the short, punchy hills you’re bound to encounter, or sections of headwind that will likely force you to work above TP for a bit. Those will all drop the focus duration from 1:00:00+ down to something likely in the 8:00-20:00 range, which is why a GC specialist or climber athlete type would be a good choice. Have you completely the DK before and uploaded the results to Xert? Or have you performed a similar ride and uploaded it to Xert? Go back and look at the Focus Duration for that activity and use that as a guide to select an athlete type this time around.
Hope that helps! Good luck with your preparation!
