I don’t get power readings even do, Stryd is paired as Ant + power meter and foot pod in running, in xert android app, please advise the best setup.
There should be no difference in how you setup the Stryd versus how you set up any other power meter. If you select “Running” as your activity type, be sure the Stryd is also configured for the Running Activity Type under the Sensors menu.
