Same issue as user below. Not syncing with STRAVA or Garmin today. Something seems broken.
Same here
same here
We’ve discovered the issue but it may take a bit of time before the system works its way through everything and gets everything back in order. If your Garmin activity has been affected (which is possible) you may need to manually upload your FIT file. Sorry for the inconvenience and thanks for your patience.
