Power to Weigh Ratio
Hi. Is there anywhere that you can see your power to weigh ratio trend over time. For example, if im on a program to lose weight, Id like to see if that weigh loss is affecting my power output. Is there anywhere I can see this measure?
You can show your power-to-weight data based on your athlete type in the Table View. There’s no chart for that in Xert but you can export your data from the table and use that for charting.
